Hi, been using ZimaOS on custom hardware for a couple of weeks now and I really love it, but there is a graphical issue with the System Settings popup window when using either Night Mode in my browser, or a Dark Mode add-on in my browser. I use Brave browser and if I turn on it’s native Night Mode setting or enable my dark mode extension for the server WebUI when I first login both the Widgets on the left and the System Settings popup don’t render correctly. The widgets go opaque and the System Settings panel is see-thru, showing the text from behind.
Weirdly, if I disable and then re-enable either Night Mode or Dark Mode extension, it then renders correctly until I next log in. Not sure if this is Brave-specific, but given it’s a Chromium browser I would guess it affects others too.
Keep up the good work.
