[Solved]USB Functionality Question
It sounds like you are connected to the same network multiple ways which that means your MAC is going to only want to use the connection that has a default route and as a result probably ignoring the cross over connection you are using to get to your zimacube.
So Try:
  1. Set the IP address of the Network Interface on your MAC that is connected to the cross over cable to be 192.168.10.5
  2. Set the IP address of the Network Interface on the Zimacube which is connected to the cross over cable to be 192.168.10.10
  3. Check to make sure you are sharing a folder via SMB on the Zimacube.
  4. See if you can get to the zimaos console via 192.168.10.10
  5. If you can connect to the zimaos console via 192.168.10.10 then you should be able to connect to the smb share using: \\192.168.10.10\
Screenshot 2024-07-23 152444
@ETWang1991 any updates on APFS support on USB Drives, by chance?
