[Solved] Lost connection zimaOS
Everything was working fine, but now suddenly on version 1.5.1, I can’t get Immich to sync, and I’ve lost all ability to sync. Has this happened to anyone else?
I don’t know if I should format from scratch and start over because I don’t know how to fix it. It’s like Zima is blocking the connection.
solved
How?
By the way, you can „mark“ your answer as the solution.
