Thank you, I installed it, but it still doesn’t Work.
I think that no drivers are installed.
We seem to have found the reason here.,The driver source has been changed from closed source to open source in this version.,Open source compatibility is not as much as closed source.,We will currently modify back to the closed source version first.,After the build is completed,Please help us verify it.
I have updated the new package, or the above address, remember to delete the old package first, and then download this new package to install
Hi, to better help users using GPUs, would you tell me how you will use GPUs in a NAS system specifically? @isanto1306
Hello, I’m currently using the GPU for Plex transcoding.
I have to admit that I still haven’t found a program that supports the graphics card load.
Would you please try Jellyfin? Especially this version:
I will try thanks
