Sabnzbd and radarr in zimaos
I have a Beelink Me Mini with ZimaOS install and a internal 256 ssd for the boot drive. the other slots will be populated later for backup storage. for now i have a 512gb external ssd attached to the mini that I or now will use for Movies and TV Shows, using Radarr and Sonarr. I have also SABnzbd installed to download the files. my issue is that after the completed files have been moved to the completed folder in the /ZimaOS-HD/AppData/sabnzbd/config/Downloads/complete, I want it then to move it to the root folder “movies” on the external ssd that i have a movies and tv shows folder setup.
Every time I think I mapped to the ssd with the movie folder i get an error ststing that file or path does not exist. SAB is processing the downloaded files in its own folders " /downloads/incomplete" and “/downloads/complete” and refuses to move the completed file to my ssd’s “movies” folder.
Hardware/OS:
Beelink Me Mini running ZimaOS v1.7
Storage:
256GB Internal SSD (Boot/OS) + 512GB External SSD mounted by ZimaOS as /media/SP_Plex_513.
The Goal:
Use SABnzbd to download files directly onto the 512GB External SSD, and have Radarr/Sonarr automatically pick them up and organize them into the final /media/SP_Plex_513/movies and /media/SP_Plex_513/TV Series folders on that same drive.
The Core Roadblock:
SABnzbd’s internal Default Base Folder is locked to /config, causing immediate directory access errors or forced nested folder loops (/ZimaOS-HD/Downloads/complete/SP_Plex_513/…) whenever Docker paths are passed between the ZimaOS App settings and the application web interfaces.
