Hello ZimaOS Development Team,
I hope this message finds you well. I am reaching out to discuss RSS (Receive Side Scaling) support for the AQC113 interface on ZimaOS. Currently, it seems that RSS is not enabled, which poses a limitation for utilizing SMB Multichannel effectively on a single 10G port.
Enabling RSS would substantially improve network performance by allowing better distribution of incoming traffic across multiple CPU cores. Given that SMB Multichannel is designed to improve throughput and fault tolerance by using multiple connections, having support for RSS is essential to fully leverage the capabilities of the AQC113 interface.
Could you consider adding this feature in a future release? It would be immensely beneficial for users relying on high-performance NAS solutions, especially those of us using the AQC113 for 10G networking.
Thank you for your hard work on ZimaOS and for considering this request. I am looking forward to your response.
