Reinstall zimaOS
Hello,
I would like to reinstall zimaOS because the photo feature is interfering with my system’s operation; ever since I enabled it, the two hard drives in my external dock have been under constant activity.
Additionally, I want to switch to a different installation SSD.
My question is:
Will a reinstallation allow me to prevent synchronization with my photo directories?
Thanks in advance for your help.
Honestly, I’m not sure how that app is interfering with things; have you tried turning it off to see what happens?
I assume the same thing will happen if you reinstall it.
In any case, I recommend removing everything and keeping it handy, just in case.
Thank a lot for your answer, but I had re install ZimaOS and every thing was ok until the last update 1.80.
Unfortunatly without asking of me my USB disk with my photo is all time running ?
I would like a solution because my external harddisk risk to grow old quikly.
How do you know it’s running constantly? I mean, if you see it running all the time, perhaps that’s just normal behavior.
I don’t have any flash drives (USB sticks) plugged into ZimaOS; the ones I have connected are USB hard drives.
In fact it’s 2 usb hard disk mounting inside docking SABRENT and I can see the activity of them.
Because my thinkcentre M715q have not the possibilité to receive my hards disks 3.5
https://youtu.be/fiz1kHDW3xw?t=4
I also had an HDD hub, and the problem with it is that it has its own separate “CPU,” so it might work or it might not (mine never worked, not even with a single HDD… that’s why I sold it).
I would advise you to take it off, but if, as you say, you can’t… then I don’t know how to help you.
I am not sure that my problem is in relation with the dock. Because why with zimaOS until V1.71 my external disks run and after about 60 minute go to sleep mode without realtion with sleep mode of zimaOS in my Thinkcentre 715q.
But with V1.80 I have an disk access about every 5 secondes and of course I have never sleep mode.
I think that is the USB management who is at origin.
I can confirm i have the same suspicion. My harddisk are noisy (but healthy) and this makes i can hear them when walking past. Also my powerconsumption went up 100 watt’s a day since the 1.8 update. I’m also considering downgrading to ZimaOS 1.7.1. I have a Github page open of 1.7.1 but didn’t bite the bullet yet. If you decide to downgrade please post your finding’s here so i can read them back. Thanks in advance!
One addition, i deleted the folder inside the photo’s app. Unfortunately this didn’t fix the issue ;(.
This is important because i already used photo back-up on the Zima app on my phone on 1.7.1. Did never increased my power consumption or pinged my drives. So there seems to be something wrong with drive suspension in 1.8. Whatever the (app) case may be.
One final addition (sorry for long message). I now have deleted the folder destination inside the photo’s app and in the ZimaOS settings i removed the folder under photo settings. If this fixed the issue i will update you later this week!
I hope that the next version will be without this problem :wink:
