RAID issues: two discs using the same serial
Hi there,
I need some help with a very specific issue.
I have two Seagate HDDs (same model and size) that unfortunately report the same serial number:
udevadm info --query=all --name=/dev/sdb | grep ID_SERIAL
E: ID_SERIAL=ST2000DM008-2EP102_ZK208F9A
E: ID_SERIAL_SHORT=ZK208F9A
udevadm info --query=all --name=/dev/sda | grep ID_SERIAL
After inspecting local-storage.json and local-storage.db, it seems that ZimaOS uses the disk serial as the primary identifier to map devices and assemble RAID arrays.
Because both disks share the same serial, zimaos-local-storage ends up treating them as a single device. Sometimes it detects /dev/sda, sometimes /dev/sdb, but never both consistently.
I can manually re-add the missing disk using:
mdadm --add /dev/md0 /dev/sdX
However, this change does not persist — it is lost after reboot (or possibly after a storage rescan).
As a result, I cannot reliably keep both disks in the RAID array.
I also tried creating and mounting the array manually (bypassing ZimaOS), and that works fine, but then I lose integration with the UI.
My question is:
Is there any way to configure ZimaOS (or zimaos-local-storage) to use a different identifier, such as WWN, instead of the disk serial?
Any guidance would be greatly appreciated.
Thanks for your feedback, can you check the blkid command, maybe we can make a bottom decision through this sub uuid
Here it comes:
/dev/sda: UUID=“e4fe9ad1-3aa6-bf5a-7121-a2a35a38ff6f” UUID_SUB=“aacf0536-4d02-6e36-f368-ac24829e05b9” LABEL=“zimaos:340ef535df13657f” TYPE=“linux_raid_member”
/dev/sdb: UUID=“e4fe9ad1-3aa6-bf5a-7121-a2a35a38ff6f” UUID_SUB=“22bd29d7-65d4-37cc-0e6c-f10fb20e8c70” LABEL=“zimaos:340ef535df13657f” TYPE=“linux_raid_member”
/dev/nvme0n1: UUID=“28450707-7c54-47d3-8902-81275e11fd98” UUID_SUB=“408e06ec-213f-493b-ae89-f7ade3e26d77” BLOCK_SIZE=“4096” TYPE=“btrfs”
/dev/mmcblk0p7: LABEL=“casaos-overlay” UUID=“db5b5e2c-f788-4ea3-9e87-e38a675eada1” BLOCK_SIZE=“1024” TYPE=“ext4” PARTLABEL=“casaos-overlay” PARTUUID=“f1326040-5236-40eb-b683-aaa100a9afcf”
/dev/mmcblk0p5: BLOCK_SIZE=“131072” TYPE=“squashfs” PARTLABEL=“casaos-system1” PARTUUID=“a3ec664e-32ce-4665-95ea-7ae90ce9aa20”
/dev/mmcblk0p3: BLOCK_SIZE=“131072” TYPE=“squashfs” PARTLABEL=“casaos-system0” PARTUUID=“8d3d53e3-6d49-4c38-8349-aff6859e82fd”
/dev/mmcblk0p1: SEC_TYPE=“msdos” LABEL_FATBOOT=“casaos-boot” LABEL=“casaos-boot” UUID=“D449-1F65” BLOCK_SIZE=“512” TYPE=“vfat” PARTLABEL=“casaos-boot” PARTUUID=“b3dd0952-733c-4c88-8cba-cab9b8b4377f”
/dev/mmcblk0p8: LABEL=“casaos-data” UUID=“6a69ff54-c162-470b-819c-ed826f1eefd7” BLOCK_SIZE=“4096” TYPE=“ext4” PARTLABEL=“casaos-data” PARTUUID=“a52a4597-fa3a-4851-aefd-2fbe9f849079”
/dev/mmcblk0p4: BLOCK_SIZE=“131072” TYPE=“squashfs” PARTLABEL=“casaos-kernel1” PARTUUID=“fc02a4f0-5350-406f-93a2-56cbed636b5f”
/dev/mmcblk0p2: BLOCK_SIZE=“131072” TYPE=“squashfs” PARTLABEL=“casaos-kernel0” PARTUUID=“26700fc6-b0bc-4ccf-9837-ea1a4cba3e65”
/dev/loop6: BLOCK_SIZE=“131072” TYPE=“squashfs”
/dev/loop4: BLOCK_SIZE=“131072” TYPE=“squashfs”
/dev/md0: UUID=“e4fe9ad1-3aa6-bf5a-7121-a2a35a38ff6f” UUID_SUB=“ec9b6c71-a865-4758-b4ac-22796240a6e8” BLOCK_SIZE=“4096” TYPE=“btrfs”
/dev/loop7: BLOCK_SIZE=“131072” TYPE=“squashfs”
/dev/zram0: UUID=“c3ba033a-f86b-4832-9b7f-5757e29e7166” TYPE=“swap”
/dev/loop5: BLOCK_SIZE=“131072” TYPE=“squashfs”
/dev/loop1: BLOCK_SIZE=“131072” TYPE=“squashfs”
/dev/mmcblk0p6: PARTLABEL=“casaos-bootstate” PARTUUID=“33236519-7f32-4dff-8002-3390b62c309d”
/dev/loop2: BLOCK_SIZE=“131072” TYPE=“squashfs”
/dev/loop0: BLOCK_SIZE=“131072” TYPE=“squashfs”
/dev/loop3: BLOCK_SIZE=“131072” TYPE=“squashfs”
Okay, we can see that the sub uuid is indeed different, and we will add a bottom logic in the next fix version, when encountering two disks with the same SN, we can use the sub uuid to judge
Nice, much appreciated!
Can’t wait for the fix!
Hi!
The fix is available in the 1.6.2 beta series?
Yes, you can try!
It worked!
