Help with starting qBittorrent.
I installed the default. I changed the connection from http to https and started it. I got an error message.
Installed on the default eMMC drive of the NAS device (64Gb).
It refers me to the generated log, I changed everything I could, but I really have no idea what to change and set.
Do I need to add a device here? I tried but to no avail
Try this version. (LinuxServer.io)
Thanks for the help, but I can’t do this. I don’t know how to install the files that are available for download.
Did you tried to add depository?
2. Add an App Store Repository (ZimaOS App Store Extension)
(only available in newer ZimaOS versions)
Open the ZimaOS Dashboard.
In the left menu, select App Store.
In the top right, click App Store Sources.
Choose “Add Source”.
Enter the URL of the repository (e.g., a community repo).
Save → the new apps will automatically appear in the store.
Thank you, but I think I have a new menu, I don’t see it as a link for adding sources, but directly for manually adding an application. …(I have combi menu = Eng + Czech language)
On the rihgt corner = add container app
next window = Manually install app
