Hello, I’m running Proxmox 8.4 on a Zimacube pro with a mixture of HDD/SSD/NVME (all slots occupied) and since it’s that time of the year again, that little buddy is getting quite hot. I’ve installed lm_sensors to monitor the termperature and the numbers are… interesting, e.g. the sensor nvme-pci-0600 reports the following values:
Sensor 1: +44.9°C (low = -273.1°C, high = +65261.8°C)
Sensor 2: +54.9°C (low = -273.1°C, high = +65261.8°C)
Sensor 8: +44.9°C (low = -273.1°C, high = +65261.8°C)
(at least, low and high are given, though just BS)
nvme-pci-0400:
Sensor 1: +41.9°C (low = -273.1°C, high = +65261.8°C)
ERROR: Can’t get value of subfeature temp3_min: I/O error
ERROR: Can’t get value of subfeature temp3_max: I/O error
Sensor 2: +65.8°C (low = +0.0°C, high = +0.0°C)
Is there a sensors configuration file for the zimacube? Or, why do I get those errors? And, neither the range -273 - 65263 is reasonable nor 0 - 0. How can I fix this?
Thanx
Uwe
