Portainer (lastest update) is not working after ZimaOS ver v1.80-beta1
Portainer (lastest update) is not working ZimaOS Ver v1.8.0-beta1. I uninstalled (Not delete data, due my license, etc..) Any Suggestions?
Anthony G.
@ATGPUD2003 Is the application failure to start? Is there any relevant log?
Hi Bin,
I just uninstall it and re-installed and got back in working order and just Installed Business Edition License Key and everything working fine, Now I just backed up in case goes boo-boo issues in the futures..
Anthony G.
Thanks for your feedback. Can Portainer be used normally after you reinstall it?
If that doesn’t work, Could you please manually run t he following command in the command line?
docker start portainer
After running it, please send us a screenshot of the error message.
Also, please click Logs on the Dashboard and send us a screenshot of the log page as well.
