Please Help with zima os
I have a zima blade and I have installed the latest zima os. I had a sata drive plugged in and migrated the system folders to the sata drive. Today i just got the splitter cable for using 2 sata drives. I installed another sata drive and wanted to setup raid 1 with them, so it asked to format the drives, which I did. Now I have my raid but the system folders, AppData and the others, are missing. It says path lost. I click the reload button but still nothing. I tried reinstalling fresh with a new image but it keeps reverting back to the old settings with the folder structure missing. How can I get this fixed? I dont know of a way to clear the emmc and when I reinstall the new image it just loads the old setup back like it was. Please help! I need to get this setup quickly if someone could help me i would apprecite it Thanks!
Did you migrate the data before assembling the RAID 1, and then directly format the SATA1 without migrating the data back, and proceed to assemble RAID 1 with two SATA1 drives? This issue sounds like a path was occupied, causing the reload error. Could you provide some screenshots of your current migration interface and a way for remote connection so we can troubleshoot the issue? Thank you for your feedback on the issue.
Thanks for the response, i eventually got it to install a fresh image. Still, my internal storage emmc only shows 17.7gb available …even after wiping it and installing fresh image.
