pi-Hole Update?
Hi everyone, how do I update Pi-Hole in ZimaOS? I know how to do it with other apps, but I can’t figure it out with Pi-Hole. When I check for updates, it doesn’t find any.
Pi-Hole tells me there’s an update available…
Bildschirmfoto 2025-11-10 um 10.13.01
Thanks
Add images
You can either manually change the image version to their latest specific release versions (eg. 2025.11.0) or just change the image settings to latest too.
Here are their release versions: Releases · pi-hole/docker-pi-hole · GitHub
