Paperless ngx issue
Hi,
I can’t install Paperless ngx on Zima OS 1.7.1 runnig on Proxmox
The installation app runs slowly till 100% that turns green. After a few seconds the 100% percentage turns grey and fall to 0. Paperless icon does not show the “NEW” sign.
If I try to launch it an Error_Connection_Refuse appears.
Same error if I try to install on Umbrel.
On Proxmox LXC everithing is ok
Any Idea?
Thankyou
UPDATE….
installed ZimaOS 1.7.1 bare metal on a server…..same error returmed
NEW UPDATE.
I solved the issue in UmbrelOS. Changed back my DNS to Cloudflare (I was testing NextDNS). Reinstall Paperles ngx on Umbrel ,and it worked.
Unfortunately this doesnt. work with ZimaOS. I install Paperless, the counter reach 100% and turns green. After a few seconds it greys out and shows 0%.
I hope there will be an app upgrade soon.
