Nvidia GPU not working in the system
Hello everyone. Sorry for my broken English, I’m writing through a translator. Not long ago, I needed to connect my video card to the system so that it could be used in containers. After a few manipulations, I realized that the system was incomplete and everything that is available in the regular version of Linux had been cut out. I can see my video card using the lspci command, but I can’t even install the drivers because the system is closed. Please advise me on what to do. Is there any way to install the drivers? And which video cards work out of the box, just plug and play? No installation required. I would like to use the graphics card’s power for decoding for some applications, as well as for face recognition via immich ml.
I would be grateful if you could let me know which video cards are supported by default in the system. I am using version 1.5.1
Hey, here you can find the support list:
