Hi everyone,
I am currently using ZimaOS version 1.5.3 and ZimaClient version 2.3.2.
The built-in hard drives are displayed correctly in the OS, but only the ZimaOS hard drive is displayed in the ZimaClient app.
Is there a way to display the additional hard drive in ZimaClient as well? The automatic mounting of drives in macOS is already a great feature.
thx in advance
I’m experiencing a similar issue. After rebooting my device, the SSD no longer appears in the UI. Does your SSD still show up in the webUI after you rebooted your system?
No, the devices itself is always visible and mounted and also accessable via the Files app.
But it doesnt show up in the ZimaClient.
I guess it has something to do with sharing or something
You can first open the SMB share in ZimaOS for the folder you want to appear, and then refresh in Zima Client, and you will be able to see the folder, like this.
That’s clear, you can make individual folders visible in the app. But how do you make the entire volume visible?
Hey, thanks for your reply.
I have created a screenshot to demonstrate the issue like yours:
Hey, I know how to solve this! Let’s try this method.
Click the edit symbol.
Delete ZimaOS-HD and press Enter.
Click on the folder you want to share.
Yes, that worked!! So simple!
Many thank
