Mirror Backup on ZimaOS
I’ve been backing up my ZimaCube but I have noticed that the backup destination has all the files that I had removed from the source, it would be great to have a Mirror feature on the Backup App so everything looks like the source.
but thankfully I was able to recover from disaster thanks to the backup app, but I had to manually re arrange all things :confused: .
+1 to that.
I know it sounds like just copy from one location to another but now Backup creates History folder with sub folders for each file and so on. This gives a lot of manual work in case of restore when restore can’t be done from the same backup setup.
Regard
Tom
You’re both right, current ZimaOS Backup is versioned, not mirrored.
That’s why deleted source files remain in the destination inside History/.
If you want the destination to always look exactly like the source, you need a true mirror (sync with delete), not versioned backup.
Right now the Backup App is designed for:
  • Disaster recovery
  • File history / rollback
  • Protection against accidental deletion
It is not designed for:
  • 1:1 live mirror
  • Clean destination identical to source
Practical Workaround (Until Mirror Option Exists)
Use rsync with delete enabled.
Example:
rsync -av --delete /DATA/source/ /DATA/destination/
What this does:
  • Copies new/changed files
  • Removes files from destination that no longer exist in source
  • Keeps folder structure identical
You can schedule this with cron or Ofelia.
Suggestion to Devs
It would be very useful to have a selectable “Mirror Mode” in the Backup App.
Current versioning is excellent for recovery, but some users need a clean 1:1 sync where deleted source files are also removed from the destination.
An optional “Mirror (Sync with Delete)” mode would solve this without removing versioned backup functionality.
Important distinction:
Backup = versioned safety
Mirror = exact sync
Both are valid. They just serve different goals.
