I need help on how to properly do library migration.
I’m running Immich on ZimaOS from the very beginning on system drive. But now as I added 2 new drives in Raid1 I would like to move Immich library there. I have checked already few topics from this forum but everyone have different approach and different issues. Is there any new updated way to move Immich library to another drive?
Do I need only to change this path /DATA/Gallery/immich to new drive and then copy folder from old path?
It depends. If you use the ZimaOS settings panel to migrate your “User database” to the new RAID storage pool you will not need to change the directory. Your data will be copied from the old storage location to the new location while keeping the same directory structure. So, the location of your gallery in the file system will still be /DATA/Gallery/immich, but the physical location of that data will change. However, if you decide to manually copy that directory onto your RAID storage pool without migrating the “User database” in the ZimaOS settings menu, then you will need to change the path in your docker-compose.yml.
Thank you all for help! I was little afraid because I seen a lot of issues while changing immich folder, but I tried what @sny recommended and it worked fine without any issues
