How to upgrade from ZimaOs 1.4.2.-beta 2 to 1.5 without losing already installed docker applications ?
Is there a step-by-step guide?
Upgrading the system will not lose your Docker program.
If the system doesn’t prompt you to upgrade. You can do the upgrading manually: Update offline | Zimaspace Docs
