Subject: How to safely rename USB storage mount points in ZimaOS v1.8.0
Hello IceWhale Support,
I am running ZimaOS v1.8.0 on a ZimaCube.
I would like to rename two existing USB storage mount points without formatting the disks or losing any data.
Disk 1
Hardware: H/W DISK 1
Serial number: 7HK78X9F
Filesystem: ext4
Current mount point:
/media/Archive_5 -
Desired mount point:
/media/Archive_4
Disk 2
Hardware: H/W DISK 2
Serial number: ZL26KB94
Filesystem: NTFS
/media/archive_2 -
/media/Archive_2
Both disks contain media files and are actively used by Docker applications:
Radarr
Sonarr
Jellyfin
Emby
I have checked the ZimaOS storage database and the .zimaos_storage.json metadata files. Both disks are currently registered under their existing mount points.
I also noticed that ZimaOS has no visible rename option in Settings → Storage.
My questions:
What is the officially supported way to rename an existing USB storage mount point in ZimaOS v1.8.0?
Can this be done without formatting or deleting any data?
Is the Eject → Create Storage → Keep All Data procedure safe when Docker containers are using the disk?
How can I ensure that the new mount points survive a reboot?
Is there a risk of ZimaOS automatically restoring the old names?
I would appreciate step-by-step instructions specific to ZimaOS v1.8.0.
Thank you for your help.
