Home Assistant, how to update?
Hello, I installed HA some months ago from the official zimaos store but I see that the app does not follow the updates. I ask you if there is a way to update HA without losing the current configuration of the devices or if I should install it from scratch. If so, how to get HA and ease of updating?
Thanx.
Set the HA image version to “latest” and use Watchtower for automatic updates; keep daily backups, and after that, you’ll never have to worry about updating again.
