HD Access after 1.8.0beta2
Hi, after the installation of the 1.8.0beta2 every 5ish seconds all HDs in my Server are accessed, evidenced by the HD drive active LEDs. I tried to figure out what happens but so far no success. It seems like no data are read or written, just that the LEDs are blinking like a christmas tree. Since I had no succes I rolled back to 1.7.1. All is “quiet” now, no blinking anymore. I don’t know if this is “as intended” or not. Just wanted to let you guys know. T.
Hi Teddylee,
Thank you for reporting this issue!
We suspect that the zimaos-device-management service might be causing the periodic disk activity you’re seeing in 1.8.0-beta2.
Would you mind helping us verify this by following these steps?
  1. Upgrade back to ZimaOS 1.8.0-beta2.
  2. Connect to your ZimaOS server via SSH.
  3. Stop the device management service by running:
sudo systemctl stop zimaos-device-management
  1. Observe the HDD activity LEDs for a few minutes and check whether the blinking every ~5 seconds continues.
If the disk activity stops after disabling the service, it would help us narrow down the root cause.
Please let us know what you find. We really appreciate your help!
Hi there,
I already did that and more:
  • The standby timer works. hdparm -S is effective, and drives sent to standby with hdparm -y stayed in standby for several minutes while the LEDs kept blinking (the interval then grew from ~5 s to ~10 s).
  • There is no real I/O. The read/write counters in /sys/block/sdX/stat did not change on any of the six drives over 60 s.
  • A block-layer trace (block_rq_issue) shows that the blink cycle consists of zero-length commands (N 512, 0 + 0) sent round-robin to all drives (8,0 … 8,80). Most of them come from zimaos-device-management, a few from my server services and zimaos.
  • Stopping one thing at a time did not change the blinking: the Photos services (zimaos-photos, zimaos-photos-ai-worker), zimaos-device-management, all Docker containers, and all server services.
My findings so far: The blinking may come from status-type commands, not from data access, and I could not find the source by stopping services.
Hope this helps. T.
Hi there,
just installed final 1.8.0. Annoying blinking still there.
Regards T.
