I am trying to install the Home Assistant full OS (HaOS) using the haos_generic-x86-64-16.2.img
I prefer HaOS over the Docker version, as I like to have everything related to Home Assistant in our VM, and the updating of the add-os is also easier and so is the backup as i have everything in one.
I have installed this many times over the year on different device without issues and for the last year it ran on my Proxmox cluster.
But when i try to install it on ZimaOS as a ZVM, it seems to run the installer just fine, netkort is mapped correct and it pulls and IP from my DHCP. I can access the webinterface, but it never completes the installer, as it says it is out of diskspace. I have assigned 32GB from my SSD pool, so there should be enough.
Any cluse ?
My assumption would be that it doesnt see the harddrive correct, but that seems odd, as I havent had that issue on other virtualization platforms…
