GMKtec K12 (Ryzen 7 H 255 / Radeon 780M) — confirmed iGPU support in ZimaOS?
GMKtec K12 (Ryzen 7 H 255 / Radeon 780M) — confirmed iGPU support in ZimaOS?CPU: AMD Ryzen 7 H 255
* iGPU: AMD Radeon 780M (RDNA 3)
* RAM: DDR5
Before purchasing, could you please confirm:
1. Is this exact iGPU supported by the current stable version of ZimaOS?
2. Is hardware acceleration working in Docker containers, with access to `/dev/dri/renderD128`?
3. Can Jellyfin or Plex use the iGPU for hardware video transcoding?
4. Can Ollama use this iGPU through Vulkan, with actual GPU inference rather than CPU fallback?
5. Is any custom configuration or workaround required?
I have seen community reports of a Radeon 780M working with Ollama through Vulkan on a Ryzen 7 8845HS system. However, I would like confirmation for the specific Ryzen 7 H 255 used in the GMKtec K12.
I’m considering this device specifically because I want to use its integrated GPU, so confirmation of actual GPU acceleration is essen
tial.
Thank you!
Hi, I tested Jellyfin and Ollama on a Ryzen AI Max+ 395 / Radeon 8060S system running ZimaOS. Jellyfin hardware transcoding worked in Docker, and Ollama completed GPU inference through Vulkan with all layers of the test model offloaded to the GPU.
ZimaOS includes the kernel driver and relevant firmware for the H 255 / 780M, so I would expect this setup to work. I haven’t tested a K12 yet, though, so I can’t confirm the same results on that exact machine.
For Jellyfin, you need to map /dev/dri, check the container’s device permissions and enable VA-API. For my Ollama test, I mapped /dev/dri and /dev/kfd and set OLLAMA_VULKAN=1. I didn’t need to change the host drivers for these tests.
Schließe mich dieser Frage an.
