FileBrowser does not let in
Since version 1.52, I haven’t been able to log in with any account. I’ve tried deleting the folder in the application and leaving everything empty to do a clean install, but there’s no way to log in. Does anyone have a solution?
Are you talking about the Filebrowser app in the App Store? If you can take some screenshots, this can help us better assist you in solving the problem.
Exactly! Since the last system update, many programs no longer work. My Mint VM won’t start either. From what I’ve read, I’m not the only one complaining about this problem.
It is not possible to log in using user credentials. Neither with the File Browser app nor with the Spacedrive app.
Thanks for replying, I’ve finally found the solution, I’m posting it in case anyone else has the same problem.
The password is in the registration; I’ll explain how to access it from the settings.
I’ve posted the solution in case it works for you, let us know.
OK. It works. Thanx
