The latest version of iOS Zima client (1.7.1) drains more battery then the previous version when it runs in background.
Thanks for letting us know, and I’m sorry you’ve been seeing increased battery drain.
Could you please check whether Automatic Backup is enabled in Zima Client? This feature was introduced in the latest version and can continue backing up your files while the app is running in the background, which may increase battery usage.
The connection type can also make a difference. Connecting to your device over the same local network generally uses less power than connecting remotely through a VPN.
To help us narrow this down, could you let us know:
- Is Automatic Backup currently enabled?
- Do you usually connect over the same local network as your device, or remotely through a VPN?
If Automatic Backup is enabled, you could try temporarily turning it off and checking whether battery usage improves. This will pause automatic backups, so please turn it back on afterward if you’d like them to continue.
Thanks for your help. Your feedback will help us better understand what’s happening.
