I’ve been using ZimaOS for a year without any issues until today; my Docker applications stopped working after a ZimaOS update. I have no idea why. I’d really rather not have to back up my data, reinstall the system, and restore everything. Do you have any ideas?
I would advise you to erase the IP address just in case from the screenshot
Oh thanks
@LaTechpourtous Can’t run, is there any error when the container starts?
I’m getting this error on all my Docker apps. I also can’t perform the 1.7.0 update. I suspect there might be an issue with a partition on my secondary drive—the one containing my movies and such—though my data itself seems unaffected.
I would like to know what version of ZimaOS you mentioned in your first post. The screenshot you provided seems to show the Jellyfin startup interface from an earlier version.
The whole server is glitching; I think I’ll end up doing a clean reinstallation. Thanks you for your help.
