Hello everyone.
Returning to linux after many years and enjoying Zima OS. but as you all know a little out-dated knowledge is a dangerous thing and I’m hoping for some advice to repair a broken install.
Context
ZimaOS HD in my system is a 180g SSD. due to my foolishness installign Immich I left the immich database on this drive. It of course filled up and threw and error.
Attempted migration via Zima OS to another drive but there was insufficent space on the OS HD to buffer. using forum posts I SSHed in and deleted .log files to create space and and migrated App data what i thought was successfully after a few failed attemps. Thanks to the forum communtiy for the posts that help the above.
The Error
When I rebooted docker failed to start. throwing this error when i try to run an app
Cannot connect to the Docker daemon at unix:///var/run/docker.sock. Is the docker daemon running?
using SSH trying to restart docker it get this
systemctl restart docker docker.socket
Failed to restart docker.service: Access denied
See system logs and ‘systemctl status docker.service’ for details.
Failed to restart docker.socket: Access denied
See system logs and ‘systemctl status docker.socket’ for details.
details of the failure
journalctl -u docker --no-pager | tail -50
Feb 03 18:35:07 ZimaOS systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Feb 03 18:35:07 ZimaOS systemd[1]: docker.service: Failed with result ‘exit-code’.
Feb 03 18:35:07 ZimaOS systemd[1]: Failed to start Docker Application Container Engine.
Feb 03 18:35:09 ZimaOS systemd[1]: docker.service: Scheduled restart job, restart counter is at 2.
Feb 03 18:35:09 ZimaOS systemd[1]: Starting Docker Application Container Engine…
Feb 03 18:35:09 ZimaOS dockerd[44575]: time=“2026-02-03T18:35:09.478964879+10:30” level=info msg=“Starting up”
Feb 03 18:35:09 ZimaOS dockerd[44575]: time=“2026-02-03T18:35:09.479445032+10:30” level=info msg=“OTEL tracing is not configured, using no-op tracer provider”
Feb 03 18:35:09 ZimaOS dockerd[44575]: time=“2026-02-03T18:35:09.479556737+10:30” level=warning msg=“failed to rename /var/lib/docker/tmp for background deletion: rename /var/lib/docker/tmp /var/lib/docker/tmp-old: file exists. Deleting synchronously”
Feb 03 18:35:09 ZimaOS dockerd[44575]: time=“2026-02-03T18:35:09.502184065+10:30” level=error msg=“mkdir /var/lib/docker/overlay2/check-overlayfs-support4087190078: no space left on device” storage-driver=overlay2
Feb 03 18:35:09 ZimaOS dockerd[44575]: time=“2026-02-03T18:35:09.502215871+10:30” level=error msg=“[graphdriver] prior storage driver overlay2 failed: driver not supported”
Feb 03 18:35:09 ZimaOS dockerd[44575]: failed to start daemon: error initializing graphdriver: driver not supported
Feb 03 18:35:09 ZimaOS systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Feb 03 18:35:09 ZimaOS systemd[1]: docker.service: Failed with result ‘exit-code’.
Feb 03 18:35:09 ZimaOS systemd[1]: Failed to start Docker Application Container Engine.
Feb 03 18:35:11 ZimaOS systemd[1]: docker.service: Scheduled restart job, restart counter is at 3.
Feb 03 18:35:11 ZimaOS systemd[1]: docker.service: Start request repeated too quickly.
Feb 03 18:35:11 ZimaOS systemd[1]: docker.service: Failed with result ‘exit-code’.
Feb 03 18:35:11 ZimaOS systemd[1]: Failed to start Docker Application Container Engine.
– Boot de5cf76b7aac450db0d3a121c65f7ae7 –
Feb 04 04:26:48 ZimaOS systemd[1]: Starting Docker Application Container Engine…
Feb 04 04:26:49 ZimaOS dockerd[1829]: time=“2026-02-04T04:26:49.349269107+10:30” level=info msg=“Starting up”
Feb 04 04:26:49 ZimaOS dockerd[1829]: time=“2026-02-04T04:26:49.351973198+10:30” level=info msg=“OTEL tracing is not configured, using no-op tracer provider”
Feb 04 04:26:49 ZimaOS dockerd[1829]: time=“2026-02-04T04:26:49.352324169+10:30” level=warning msg=“failed to rename /var/lib/docker/tmp for background deletion: rename /var/lib/docker/tmp /var/lib/docker/tmp-old: file exists. Deleting synchronously”
Feb 04 04:26:49 ZimaOS dockerd[1829]: time=“2026-02-04T04:26:49.424333538+10:30” level=error msg=“Failed to ensure default apparmor profile is loaded” error=“AppArmor enabled on system but the docker-default profile could not be loaded: write /var/lib/docker/tmp/docker-default130330059: no space left on device”
Feb 04 04:26:49 ZimaOS dockerd[1829]: time=“2026-02-04T04:26:49.447376127+10:30” level=error msg=“mkdir /var/lib/docker/overlay2/check-overlayfs-support134555568: no space left on device” storage-driver=overlay2
Feb 04 04:26:49 ZimaOS dockerd[1829]: time=“2026-02-04T04:26:49.447404787+10:30” level=error msg=“[graphdriver] prior storage driver overlay2 failed: driver not supported”
Feb 04 04:26:49 ZimaOS dockerd[1829]: failed to start daemon: error initializing graphdriver: driver not supported
Feb 04 04:26:49 ZimaOS systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Feb 04 04:26:49 ZimaOS systemd[1]: docker.service: Failed with result ‘exit-code’.
Feb 04 04:26:49 ZimaOS systemd[1]: Failed to start Docker Application Container Engine.
Feb 04 04:26:49 ZimaOS systemd[1]: docker.service: Consumed 153ms CPU time, 93.4M memory peak.
Feb 04 04:26:51 ZimaOS systemd[1]: docker.service: Scheduled restart job, restart counter is at 1.
Feb 04 04:26:51 ZimaOS systemd[1]: Starting Docker Application Container Engine…
Feb 04 04:26:51 ZimaOS dockerd[2238]: time=“2026-02-04T04:26:51.753252083+10:30” level=info msg=“Starting up”
Feb 04 04:26:51 ZimaOS dockerd[2238]: time=“2026-02-04T04:26:51.754029286+10:30” level=info msg=“OTEL tracing is not configured, using no-op tracer provider”
Feb 04 04:26:51 ZimaOS dockerd[2238]: time=“2026-02-04T04:26:51.754240646+10:30” level=warning msg=“failed to rename /var/lib/docker/tmp for background deletion: rename /var/lib/docker/tmp /var/lib/docker/tmp-old: file exists. Deleting synchronously”
Feb 04 04:26:51 ZimaOS dockerd[2238]: time=“2026-02-04T04:26:51.771557142+10:30” level=error msg=“Failed to ensure default apparmor profile is loaded” error=“AppArmor enabled on system but the docker-default profile could not be loaded: write /var/lib/docker/tmp/docker-default3759331356: no space left on device”
Feb 04 04:26:51 ZimaOS dockerd[2238]: time=“2026-02-04T04:26:51.777913426+10:30” level=error msg=“mkdir /var/lib/docker/overlay2/check-overlayfs-support3232796386: no space left on device” storage-driver=overlay2
Feb 04 04:26:51 ZimaOS dockerd[2238]: time=“2026-02-04T04:26:51.777938293+10:30” level=error msg=“[graphdriver] prior storage driver overlay2 failed: driver not supported”
Feb 04 04:26:51 ZimaOS dockerd[2238]: failed to start daemon: error initializing graphdriver: driver not supported
Feb 04 04:26:51 ZimaOS systemd[1]: docker.service: Main process exited, code=exited, status=1/FAILURE
Feb 04 04:26:51 ZimaOS systemd[1]: docker.service: Failed with result ‘exit-code’.
Feb 04 04:26:51 ZimaOS systemd[1]: Failed to start Docker Application Container Engine.
Feb 04 04:26:53 ZimaOS systemd[1]: Stopped Docker Application Container Engine.
Feb 04 04:26:53 ZimaOS systemd[1]: Starting Docker Application Container Engine…
Feb 04 04:26:53 ZimaOS systemd[1]: docker.service: Deactivated successfully.
Feb 04 04:26:53 ZimaOS systemd[1]: docker.service: Start request repeated too quickly.
Feb 04 04:26:53 ZimaOS systemd[1]: docker.service: Failed with result ‘start-limit-hit’.
Feb 04 04:26:53 ZimaOS systemd[1]: Failed to start Docker Application Container Engine.
Any advice appreciated, haven’t used docker much and a forum search hasn’t shown many options other than the SSH manaual start (which fails)
thanks.
system details for reference
ZimaOS v1.5.3 Plus
intel(R) N150
4 Cores2.90 GHz 4 Threads
1 RAM 16 GB total
4800 MHzDDR5
GPU
Intel Corporation Alder Lake-N [Intel Graphics]
