I installed NPM on ZimaOS and had to changed the ZimaOS dashboard from port 80 to another one (I went with 8080 and did so via the ZimaOS dashboard UI), and since then a bunch of things stopped working:
The CPU, RAM widgets stopped live updating, the Traffic widget shows no activity at all.
The ZimaOS Android companion app doesnt show anything. When I click “Install” to Install a custom container, visually nothing happens (the custom install window wont automatically close), and I have to refresh the page to see the app is installing.
I am running ZimaOS v1.6.2, but i changed the ports while i was running the version before it.
Is this a known issue? How can I fix it?
P.S. I have read this issue but it isn’t helpful.
