Hey,
I’m just moving over from Casa and want to install the Transmission (vpn) app. It’s not in the app store I have by default so I tried using the custom app, import, Docker CLI install… But it doesn’t do anything when I click the Submit button.
So then I followed the guides to try and install the Casa to Zima transfer app in the same way but it also does nothing.
Does this feature not work or something? Or is there a better torrent app with a vpn built in I can use?
Atm I’ve installed a VM with Mint and am just running a vpn and a torrent app on that, but it’s a bit roundabout for such a simple thing isn’t it?*
Edit: Well, I wrote this while the VM was installing but I can’t install things through the terminal so can’t go that route either :’)
