¿Alguien sabe cómo configurar y activar Link Aggregation (LACP 802.3ad) en ZimaOS desde la Terminal? Ya que desde la interfaz web no es posible
ZimaOS doesn’t support 802.3ad Link Aggregation in the WebUI, and I suggest avoiding manual bonding from the Terminal. The network layer is managed by internal system modules, and any manual bond usually breaks networking after a reboot or gets overwritten.
For higher throughput, SMB Multichannel or protocol-level parallelism is the safest option for now. Manual LACP configuration can cause DHCP loss, interface problems, and general instability because ZimaOS doesn’t use standard Debian-style networking.
If ZimaOS adds native bonding support in the future, it will appear directly in the Network settings.
