How can I install nut-client on ZimaOS with out using peanut?
Using ZimaOS + v1.7.0 on own hardware.
You don’t need to install nut-client separately. ZimaOS is Buildroot-based and doesn’t have a package manager like apt, so installing additional packages on the host isn’t officially supported. Since ZimaOS 1.5.3, NUT support is already built into the operating system for the native UPS feature. If you need a custom NUT client, it’s recommended to either use the built-in UPS service or run a NUT client in Docker instead of modifying the host system.
