Bug in v1.3.3: DNS settings not shown in GUI
I set a specific DNS server. But after reentering the network settings, it does show ‘no’ instead the correct IP:
Checking /etc/resolv.conf reveals the desired DNS server is applied correctly:
nameserver 192.168.178.1
nameserver 8.8.8.8
It does also reveal that Google’s DNS server is hardcoded into ZimaOS. What is the exact reason for that?
ZimaOS: v1.3.3
Hardware: Generic x86
AFAIR, it used to work fine with 1.3.2 and before.
You mean the manually fixed DNS is displayed as no. But in /etc/resolv.conf, it is shown properly. Am I right?
Would you please reproduce it and record the screen for us to locate the issue?
Exactly.
Here we go:
Thanks for your feedback. It will be fixed in 1.4.0.
Can confirm, thanks for the quick fix!
