**here are the results of the commands. I tried to format the text from the screenshots with chatgpt.
lsblk -o NAME,SIZE,FSTYPE,LABEL,UUID,MOUNTPOINTS**
NAME SIZE FSTYPE LABEL UUID MOUNTPOINTS
sda 114.6G
sdb 10.9T linux_raid_member zimaos:fc5616382c017331 407a8dc6-4fb3-84e2-1832-b7da3249d9bd
└─md127 43.7T btrfs 407a8dc6-4fb3-84e2-1832-b7da3249d9bd
sdc 12.7T linux_raid_member zimaos:fc5616382c017331 407a8dc6-4fb3-84e2-1832-b7da3249d9bd
sdd 12.7T linux_raid_member zimaos:fc5616382c017331 407a8dc6-4fb3-84e2-1832-b7da3249d9bd
sde 10.9T linux_raid_member zimaos:fc5616382c017331 407a8dc6-4fb3-84e2-1832-b7da3249d9bd
sdf 10.9T linux_raid_member zimaos:fc5616382c017331 407a8dc6-4fb3-84e2-1832-b7da3249d9bd
nvme1n1 119.2G
├─nvme1n1p1 32M vfat casaos-boot 62EB-BDA7 /mnt/boot
├─nvme1n1p2 24M squashfs
├─nvme1n1p3 6G squashfs
├─nvme1n1p4 24M squashfs
├─nvme1n1p5 6G squashfs
├─nvme1n1p6 8M
├─nvme1n1p7 96M ext4 casaos-overlay 8ed454ec-8396-48ca-96c0-a72ca3265f52 /
└─nvme1n1p8 107.1G ext4 casaos-data 5bc1654b-e46f-43f4-9bd0-537bc50bdad3 /var/log
/var/lib/casaos_data
nvme2n1 465.8G btrfs 0b8c6c22-027d-49b3-bb8e-9af66f43f738
nvme0n1 465.8G btrfs a3676d6a-01f8-40d7-adf3-3e6bdb079acb
| Device |
Size |
Purpose |
| sdb–sdf |
57.1 TB raw |
RAID member disks |
| md127 |
43.7 TB usable |
Btrfs RAID array |
| nvme1n1 |
119.2 GB |
OS/CasaOS boot drive |
| nvme0n1 |
465.8 GB |
Btrfs SSD |
| nvme2n1 |
465.8 GB |
Btrfs SSD |
from the blkid command
/dev/sdf:
UUID=“407a8dc6-4fb3-84e2-1832-b7da3249d9bd”
UUID_SUB=“b2d666b8-4030-bd48-90bb-cb01352dc292”
LABEL=“zimaos:fc5616382c017331”
TYPE=“linux_raid_member”
/dev/nvme0n1:
UUID=“a3676d6a-01f8-40d7-adf3-3e6bdb079acb”
UUID_SUB=“e02deffd-20f8-41df-991f-774a5d155c97”
BLOCK_SIZE=“4096”
TYPE=“btrfs”
/dev/sdd:
UUID_SUB=“00528f66-fdab-fbc7-9187-df436a3bb38c”
/dev/md127:
UUID_SUB=“19c1c2cc-d8bc-419d-a1e5-890d14ca7bcc”
BLOCK_SIZE=“4096”
TYPE=“btrfs”
/dev/sdb:
UUID_SUB=“9cd908c8-1fc7-72b6-1941-576a5475c0d3”
/dev/nvme2n1:
UUID=“0b8c6c22-027d-49b3-bb8e-9af66f43f738”
UUID_SUB=“4cfaba81-02cc-17e1-4205-9349-57c70224ba2”
BLOCK_SIZE=“4096”
TYPE=“btrfs”
/dev/sdc:
UUID_SUB=“1978cf72-f1f0-50a5-6e3b-10cc8bc0a271”
/dev/nvme1n1p4:
BLOCK_SIZE=“131072”
TYPE=“squashfs”
PARTLABEL=“casaos-kernel1”
/dev/nvme1n1p2:
BLOCK_SIZE=“131072”
TYPE=“squashfs”
PARTLABEL=“casaos-kernel0”
/dev/nvme1n1p7:
LABEL=“casaos-overlay”
UUID=“8ed454ec-8396-48ca-96c0-a72ca3265f52”
TYPE=“ext4”
PARTLABEL=“casaos-overlay”
/dev/nvme1n1p5:
BLOCK_SIZE=“131072”
TYPE=“squashfs”
PARTLABEL=“casaos-system1”
/dev/nvme1n1p1:
SEC_TYPE=“msdos”
LABEL_FATBOOT=“casaos-boot”
UUID=“62EB-BDA7”
BLOCK_SIZE=“512”
TYPE=“vfat”
PARTLABEL=“casaos-boot”
/dev/nvme1n1p8:
LABEL=“casaos-data”
UUID=“5bc1654b-e46f-43f4-9bd0-537bc50bdad3”
BLOCK_SIZE=“4096”
TYPE=“ext4”
PARTLABEL=“casaos-data”
/dev/nvme1n1p6:
PARTLABEL=“casaos-bootstate”
The result from the cat command was extremely hard to capture from a 27” 4k screen
extractable part from the cat command:
BOOT_IMAGE=root=PARTUUID=
ro
result
fsrro.enabled=1
sram_dev.board=3
net.naming-scheme=v250
systemd.machine_id=
fsck.repair=yes
console=tty0
quiet
splash
loglevel=3
systemd.show_status=1
rd.udev.log_level=3
vt.handoff=1
biosdevname=0
from the dmesg command:
bash-5.2# dmesg -T | grep -Ei “nvme|I/O|Buffer|error|ext4|superblock|reset|timeout|critical|media”
[Thu Jun 25 16:57:05 2026] Command line: BOOT_IMAGE=(hd3,gpt4)/bzImage root=PARTUUID=…
[Thu Jun 25 16:57:05 2026] Kernel command line: BOOT_IMAGE=(hd3,gpt4)/bzImage root=PARTUUID=…
[Thu Jun 25 16:57:06 2026] systemd[1]: systemd.unit=recovery.target
[Thu Jun 25 16:57:06 2026] nvme nvme0: pci function 0000:10:00.0
[Thu Jun 25 16:57:06 2026] nvme nvme1: pci function 0000:02:00.0
[Thu Jun 25 16:57:06 2026] nvme nvme2: pci function 0000:05:00.0
[Thu Jun 25 16:57:06 2026] nvme nvme1: allocated 8 MiB host memory buffer.
[Thu Jun 25 16:57:06 2026] nvme nvme1: 8/0/0 default/read/poll queues
[Thu Jun 25 16:57:06 2026] nvme nvme0: D3 entry latency set to 8 seconds
[Thu Jun 25 16:57:06 2026] nvme nvme1: Ignoring bogus Namespace Identifiers
[Thu Jun 25 16:57:06 2026] nvme1n1: p1 p2 p3 p4 p5 p6 p7
[Thu Jun 25 16:57:06 2026] nvme nvme2: 15/0/0 default/read/poll queues
[Thu Jun 25 16:57:06 2026] nvme nvme0: allocated 64 MiB host memory buffer.
[Thu Jun 25 16:57:06 2026] nvme nvme0: 12/0/0 default/read/poll queues
[Thu Jun 25 16:57:06 2026] ata1: SATA link down (SStatus 0 SControl 300)
[Thu Jun 25 16:57:24 2026] nvme1n1: I/O Cmd(0x2) @ LBA 25348616, 256 blocks, I/O Error (sct 0x2 / sc 0x81)
[Thu Jun 25 16:57:24 2026] critical medium error, dev nvme1n1, sector 25348616 op 0x0:(READ) flags 0x80700 phys_seg 18 prio class 0
[Thu Jun 25 16:57:24 2026] Buffer I/O error on dev nvme1n1, logical block 67, async page read
[Thu Jun 25 16:57:24 2026] critical medium error, dev nvme1n1, sector 25348632 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[Thu Jun 25 16:57:24 2026] critical medium error, dev nvme1n1, sector 25348616 op 0x0:(READ) flags 0x80700 phys_seg 3 prio class 0
[Thu Jun 25 16:57:24 2026] nvme1n1: I/O Cmd(0x2) @ LBA 25348632, 8 blocks, I/O Error (sct 0x2 / sc 0x81)
[Thu Jun 25 16:57:24 2026] critical medium error, dev nvme1n1, sector 25348632 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[Thu Jun 25 16:57:24 2026] Buffer I/O error on dev nvme1n1p7, logical block 67, async page read
[Thu Jun 25 16:57:24 2026] nvme1n1: I/O Cmd(0x2) @ LBA 25360904, 64 blocks, I/O Error (sct 0x2 / sc 0x81)
[Thu Jun 25 16:57:24 2026] critical medium error, dev nvme1n1, sector 25360904 op 0x0:(READ) flags 0x80700 phys_seg 5 prio class 0
[Thu Jun 25 16:57:25 2026] EXT4-fs (nvme1n1p7): warning: mounting fs with errors, running e2fsck is recommended
[Thu Jun 25 16:57:25 2026] EXT4-fs (nvme1n1p7): mount failed
[Thu Jun 25 16:57:25 2026] EXT4-fs (nvme1n1p8): couldn’t mount because of unsupported optional features …
[Thu Jun 25 16:57:25 2026] amd_pmc … SMU timeout …
[Thu Jun 25 17:00:22 2026] nvme1n1: I/O Cmd(0x2) …
[Thu Jun 25 17:00:22 2026] critical medium error, dev nvme1n1 …
[Thu Jun 25 17:00:22 2026] Buffer I/O error on dev nvme1n1p7, logical block 67, async page read
[Thu Jun 25 17:09:12 2026] nvme1n1: I/O Cmd(0x2) …
[Thu Jun 25 17:09:12 2026] critical medium error, dev nvme1n1 …
[Thu Jun 25 17:09:12 2026] Buffer I/O error on dev nvme1n1p7, logical block 67, async page read
[Thu Jun 25 17:14:53 2026] nvme1n1: I/O Cmd(0x2) …
[Thu Jun 25 17:14:53 2026] critical medium error, dev nvme1n1 …
[Thu Jun 25 17:14:53 2026] Buffer I/O error on dev nvme1n1p7, logical block 67, async page read
[Thu Jun 25 17:46:30 2026] nvme1n1: I/O Cmd(0x2) …
[Thu Jun 25 17:46:30 2026] critical medium error, dev nvme1n1 …
[Thu Jun 25 17:46:30 2026] Buffer I/O error on dev nvme1n1p7, logical block 67, async page read
From the sortctl command:
bash-5.2# smartctl -x /dev/nvme1n1
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.12.25] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Number: AirDisk 128GB SSD
Serial Number: QGB656B007477P110N
Firmware Version: SN1509B
PCI Vendor/Subsystem ID: 0x1e4b
IEEE OUI Identifier: 0x3a5a27
Total NVM Capacity: 128,035,676,160 [128 GB]
Unallocated NVM Capacity: 0
Controller ID: 0
NVMe Version: 1.4
Number of Namespaces: 1
Namespace 1 Size/Capacity: 128,035,676,160 [128 GB]
Namespace 1 Formatted LBA Size: 512
Namespace 1 IEEE EUI-64: 3a5a27 03500004d5
Local Time is: Thu Jun 25 17:22:12 2026 UTC
Firmware Updates (0x1a): 5 Slots, no Reset required
Optional Admin Commands (0x0017): Security Format Frmw_DL Self_Test
Optional NVM Commands (0x001f): Comp Wr_Unc DS_Mngmt Wr_Zero Sav/Sel_Feat
Log Page Attributes (0x06): Cmd_Eff_Lg Ext_Get_Lg
Maximum Data Transfer Size: 128 Pages
Warning Comp. Temp. Threshold: 90 Celsius
Critical Comp. Temp. Threshold: 95 Celsius
Supported Power States
St Op Max Active Idle RL RT WL WT Ent_Lat Ex_Lat
0 + 6.50W - - 0 0 0 0 0 0
1 + 5.00W - - 1 1 1 1 0 0
2 + 3.60W - - 2 2 2 2 0 0
3 - 0.0500W - - 3 3 3 3 5000 10000
4 - 0.0025W - - 4 4 4 4 8000 45000
Supported LBA Sizes (NSID 0x1)
Id Fmt Data Metadt Rel_Perf
0 0 512 0 0
=== START OF SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
SMART/Health Information (NVMe Log 0x02)
Critical Warning: 0x00
Temperature: 33 Celsius
Available Spare: 100%
Available Spare Threshold: 10%
Percentage Used: 3%
Data Units Read: 1,380,022 [706 GB]
Data Units Written: 3,013,555 [1.54 TB]
Host Read Commands: 133,991,379
Host Write Commands: 120,782,615
Controller Busy Time: 276
Power Cycles: 66
Power On Hours: 238
Unsafe Shutdowns: 16
Media and Data Integrity Errors: 76
Error Information Log Entries: 0
Warning Comp. Temperature Time: 0
Critical Comp. Temperature Time: 0
Temperature Sensor 1: 33 Celsius
Temperature Sensor 2: 35 Celsius
Error Information (NVMe Log 0x01, 16 of 64 entries)
No Errors Logged
Read Self-test Log failed: Invalid Field in Command (0x002)
bash-5.2#
from the nvme smart-log /dev/nvme1n1 command
bash-5.2# nvme smart-log /dev/nvme1n1
Smart Log for NVME device:nvme1n1 namespace-id:ffffffff
critical_warning : 0
temperature : 32 C
available_spare : 100%
available_spare_threshold : 10%
percentage_used : 3%
endurance_group_critical_warning_summary : 0
data_units_read : 1380022
data_units_written : 3013556
host_read_commands : 133991379
host_write_commands : 128782771
controller_busy_time : 276
power_cycles : 66
power_on_hours : 238
unsafe_shutdowns : 16
media_errors : 76
num_err_log_entries : 0
Warning Temperature Time : 0
Critical Composite Temperature Time : 0
Temperature Sensor 1 : 32 C
Temperature Sensor 2 : 35 C
Thermal Management T1 Trans Count : 0
Thermal Management T2 Trans Count : 0
Thermal Management T1 Total Time : 0
Thermal Management T2 Total Time : 0
and the final e2fsck command:
bash-5.2# e2fsck -fn /dev/nvme1n1p7
e2fsck 1.47.2 (1-Jan-2025)
Warning: skipping journal recovery because doing a read-only filesystem check.
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
Error reading block 271 (Input/output error) while reading inode and block bitmaps. Ignore error? no
e2fsck: Can’t read an inode bitmap while retrying to read bitmaps for casaos-overlay
e2fsck: aborted
bash-5.2#
