Dear Support, I am based in China and I am using a Huawei device which does not have any google stuff. I have downloaded the client apk file and manually installed it via file manager.
When I open the client app on my Huawei device, it is showing “Something went wrong. Check that Google Play is enabled on your device and that you’re using an up-to-date version before opening the app. If the problem persists try reinstalling the app.” and there is no option to bypass this message.
Apparently I can’t make Google Play on my Huawei device due to various constraints, is there any workaround on thisi?
By the way, is there any plan to get a Zima client app on iOS?
