Add SSH to Dashboard UI
If you have Web-based SSH enabled (in red), you can use the same link as a ‘new’ external link to create a shortcut on the dashboard (in green).
Hope this is what you’re after.
I cannot even open the webbased terminal.
not using local ip, not using remote ip, not using local domain name
