2 Mini pc working as one
I have 2 mini pc’s was wondering if i can use them together on one client, one containing the drives and other for apps, currently only running Jellyfin but keen to add some more without slowing down the pc with the drives, I know proxmox is a solution and have one running home assistant but finding sharing drives with it too complicated (want an easy setup not a big learning curve).
HP G2 800 mini i5 all 3 is the same, one with drives i have a pcie to 6 sata adapter.
Well if you need to share drives between the nodes you will need to have (1) an HBA, (2) possibly a few SAS expanders/backplanes with dual port support, (3) a SAS switch with multipath support and (4) SAS dual port drives only. Those would be the most basic requisites to achieve what you want.
Even if you can afford a few thousand dollars for a modern SAS3 switch you would still have to figure out a way to hook up an HBA to your mini PC’s, probably through some overly complicated and unreliable approach with M.2 to PCIe adapters.
Lastly, deploying and configuring SAS multipath at the OS without using something proprietary (eg. IBM, HPE, Lenovo, Dell, QLogic, etc) is not something for the faint of heart. Managing to get all the backplanes, expanders, HBAs and disks to agree on driver and firmware compatibility without a proprietary solution is not something one should not wish even to their worse enemy. lol
If you want to keep things simple, just set up the pc with the drives as a nfs server and then, either mount the shares in your client, or (even better) just use docker’s nfs driver for your volumes.
PS : if you don’t know where to start, this little tutorial explains the two options :slight_smile:
Need to clear up my question, I have Zima running already with pcie expansion and drives but i want to keep that mini pc only as nas and Jellyfin server. want to use second mini pc with zima os installed not for storage but apps. My question is can i control 2 mini pc with Zima os and control in one Zima client
Currently, the Zima client supports management and switching between multiple devices.
